Some bad layers...
Posted: Tue Dec 27, 2016 5:52 am
by rabbit
dear printer-companions :D
I hope you all had a great christmas-time... :)
My RostockV2 with the upgrades was running some prints. Everything smooth.
But now I am having strange results.
Some layers are like squeezed out. Hard to discribe.I hope you can see it on the pic.
I am printing with PLA at about 190/195°C with heatbed 50°C,
0.3mm layerheight, infill 25% and the speed at 80mm/s
does anyone of you guys have an idea what causes this unclean layers?
thank you so much
Re: Some bad layers...
Posted: Tue Dec 27, 2016 8:27 am
by joe
It look like some play or looseness in the nozzle/effector. Is the nozzle loose? One of the belts loose?
Posted: Tue Dec 27, 2016 3:29 pm
by rabbit
Thank you for your advice Joe. I tightened the belts. I got to admit the correct belt tension is a big mystery to me :lol:
Nozzle and the rest seems to be tight. I will now try to print some callibration boxes.
Great to have you guys here.
...and again a big thank you :)
Posted: Tue Dec 27, 2016 11:07 pm
by RichWP
Hello,
I am having similar problems with prints on my RMv3... I will check my belt tension - but like rabbit - I don't really know what amount of tension is correct.
Also, I assume that having the same amount of tension on all three belts is a good thing.
Is there a tool or technique that someone can recommend to help get this right?
Thanks in advance!
Posted: Wed Dec 28, 2016 4:16 am
by rabbit
good question RichWP! :D
I tightened the belts but the results are not better. it is really strange cause a few days ago everything was fine.
it is really frustrating cause I need to get it working fast. like always when you need it to work something gets in the way :?
Posted: Wed Dec 28, 2016 2:16 pm
by rabbit
could it be that the walls are to thin? the model I try to print is only 2mm thick!
