He280 upgrade on max V2 . Y axis inverted
Posted: Sun Jan 01, 2017 12:15 am
After purchasing a fully assembled HE280 and Wire Harness I finished my
upgrade of the new HE280 on me DYI Rostock V2 MAX.
When I originally assembled this base V2 months ago Ive been successfully
printing for months.
After the HE280 Upgrade, I followed these steps:
#1 - Cleared the Eprom
#2 - Grabbed the newest V92.2 of the firmware, compiled and uploaded
successfully. When using MatterControl to send HOME, Y Axis seems to move
Down (as a much slower speed then X and Z) , While X and Z speed to the
top.
So, power off
#1 - Clear E-prom
#2 - Modify configuration.h to Select V2
No change, still inverted
#1 - Clear E-prom
#2 - Modify configuration.h to Select Older Power Supply
No change, Y still inverted
#1 - Clear E-prom
#2 - Modify configuration.h to Select Older Power Supply AND V3
No Change, Y still Inverted
I have pulled the Rambo board and verified no pinched cables, no damaged
leads on Y-axis connecter. Verified X, Y, Z and ES0 are all plugged into
appropriate connection.
Any ideas?
top.
So, power off
#1 - Clear E-prom
#1 - Clear E-prom
#1 - Clear E-prom
Any ideas?
