Upgraded 2014's Repeteir firmware to most recent... temp sensor problems now
Artesian
Post by Artesian »
I use a mostly stock Rostock Max V2, except I use a Budaschnozzle with a Honeywell 100K axial thermistor, carbon arms, and a flying extruder. It's super simple to change most of the hardware parameters, and I could migrate really easily to a point where the printer basically works... except...
It has the wrong thermistor settings. I'm positive. The print quality of actual filament is really bad.
I need to know how to point the config.h file to the proper thermistor table, which should be type 67 in extruder.cpp? Maybe? I exchanged the number 97 for 67 at line 90 in the code, and it didn't work at all. When I do that, the thermistors both read DEF DEF and the printer doesn't work at all!
Any assistance appreciated!
