Updated firmware now led ring is flickering
Posted: Fri Jan 20, 2017 4:19 pm
by deadpool66
Hi everyone,
I just installed an e3d into my rostock max v2. Wired everything up piggy backing the led ring to the pfte fan tested worked great.
Installed new firmware and now its flickering any ideas why this might be happening?
Re: Updated firmware now led ring is flickering
Posted: Sat Jan 21, 2017 4:42 am
by johndeere6110
You have the probe board i tink
I tink you need to set the piek fan speed to 255 in the eeprom i have that to whit the light ring.
If you dont get it i post a picture
Posted: Sat Jan 21, 2017 12:56 pm
by deadpool66
I think your right because I hooked it up the cooling fan and at full speed it doesn't flicker.
Any idea which setting in the eeprom is the peek fan. I could not find the setting.
It is the trick lazer led ring.
Posted: Sun Jan 22, 2017 11:00 pm
by deadpool66
Is this the line I should change?
#define PDM_FOR_COOLER 0
Posted: Mon Jan 23, 2017 6:40 am
by johndeere6110
i do dat in octoprint. i dont now
Posted: Mon Jan 23, 2017 6:50 am
by johndeere6110
or you use mattercontrol to go to the eeprom
