The Z height 1.7 mm ghost
Posted: Fri Jan 27, 2017 1:49 pm
by Canadian Fenix
Hello, i'm having issues calibrating my Rostock Max V2.
The symptom im experiencing is:
- after calibration, the first layer begins printing at approximately 1.7mm off the bed.
the calibration technique i am using is:
1. Ensure all Stop screws are evenly protruding
2. home towers and set new Z height (approx 0.3mm)
3. Save new Z height
4. run matter controller software print leveling (3 point)
5. test print
Every time i test print, it is approximately 1.7 mm higher that the new z height (consistently across all axis)
If I bury the head into the galss/tape (by at least 1.7mm) I can force the first layer to print at a height that adheres to the bed but the quality is never exact and difficult to determine "how hard i need to push the head against the bed" to get the perfect first layer.
im considering upgrading the firmware and doing a factory reset but i wanted to ask the question first. i built this printer about 18 months ago and have not upgraded the arms or head. the firmware probably has a new version since then i figure.
Re: The Z height 1.7 mm ghost
Posted: Fri Jan 27, 2017 6:57 pm
by Dale Eason
The last time I read the V2 Manual about 1/2 year ago I don't remember what you are doing being what it recommended to calibrate the machine.
If I'm right then go back and read the V2 calibration procedure.
Dale
Posted: Sun Jan 29, 2017 10:59 am
Yeah, that's not the calibration process. I'm not even sure if it's A calibration process. :D
