Need help with Rostock Max v3 Cura setup
Posted: Fri Feb 03, 2017 10:42 am
Hi guys. Any luck using (latest) Cura with the Rostock Max v3?
Finished assembly a couple of days ago and got the printer to print fine with gcode generated with Matter Control.
I got the setting files for importing with cura at the SeeMeCNCs GitHub but the problem is the machine settings, there are only cartesian work areas to choose. I am looking for a Rostock Max v3 .josn file and the .stl for work area would be nice too.
The problem is that currently when I start the .gcode generated with Cura, after getting to the desired temperature it starts a triangle instead of a square (cube base) and on one edge of the glass.
There are lots of cool setting files for Cura that I am eager to try but I'm facing this issue.
