Rostock Max V3 Really having a hard time getting my first layer down
Posted: Wed Feb 15, 2017 11:47 am
TL;DR Clicking extruder and I think I am missing something here on calibrating the z-height all around the bed, not just the center.
Current Setup:
Rostock Max v3
.5mm Stainless Nozzle
Firmware 20170201 (Edit: I totally dislexed the firmware version)
Cura 2.31 with varying initial heights of .08, .1, .15, .2, .25.
Varying Print Speeds from 40mm/s up to 100mm/s
Varying hot end temps, 170, 175, 180, 190, 200, 205, 210, 220, 230
With multiple PLA brands: Hatchbox, Monoprice, MG Chemicals.
Up until now, I have just been printing small things. My first attempt at something over a few inches wide was a disaster and continues to be. I have been tweaking and printing the last few days with minimal change in my results. The middle seems to be just right (maybe even a little thin), and the further out from center I get, the higher the nozzle is. I also get clicking from the extruder during the first few layers to the point where I had to take it apart and clean it out from all the chewed up filament. Which I figured was either a temperature issue, the ptfe issue noted below, or a z height issue. (Not that I can find.)
http://forum.seemecnc.com/viewtopic.php?f=36&t=7361
I have read through that post multiple times trying to figure out what I am missing.
And I also have followed the recommendation here: https://seemecnc.zendesk.com/hc/en-us/a ... lament-JAM
I have ran the advanced calibration a few times and am within .05
I have manually adjusted my z height to around .08 as the auto calibration always sets it way to low. (Used a piece of paper that measured .08 on my caliper until it just barely dragged.)
I have attempted printing this disc so many times I have lost count, the results are always similar to the picture below. The center still appears to be thin, but if I raise the z-height anymore it doesn't lay properly at all. And the further outside of center the higher the z height appears to become.
Here's what the 2mm tall disc print from the strategy thread looks like.
Current Setup:
Rostock Max v3
