Stock MAX v1 upgrade path
Posted: Sun Feb 19, 2017 8:27 pm
I've had the Rostock Max since mid 2013. Other than adding one fan to the hot end, and one onto the board it is pretty much stock. It had been running pretty good as is for years. The calibration could have been better, and the slicing could have been easier to setup. But for the most part the prints we good enough for what I needed. Now the hot end is messed up with a clogged nozzle that resulted in the lining melting and tube connector breaking.
I have a choice to make. Replace just the broken parts, recalibrate, and go.
OR
Do the updates that I have been meaning to do anyway.
My 3 objectives are
1. Get a working printer again in a short amount of time. Use parts on hand, standard software configurations, easy calibration.
2. Keep the setup in a supportable configuration. No odd ball parts just to make it work.
3. Keep the cost the down. With the Max v3 at $999 and 10 hours of build time, the upgrade should be reasonable. ~$300
For an upgrade, I am looking at
$39 Carriage set https://www.seemecnc.com/collections/pa ... rriage-set
$39 Ball-cup kit https://www.seemecnc.com/collections/pa ... ta-arm-kit
$135 HE280 https://www.seemecnc.com/collections/pa ... eter-probe
$25 Hotend Whip https://www.seemecnc.com/collections/pa ... 2529876676
~$240 and 5 hours of work?
Simple replacement costs would be
$9 .35mm Noozle https://www.seemecnc.com/collections/pa ... ine-nozzle
$4 4mm Quick Connect https://www.seemecnc.com/collections/pa ... tc-fitting
$5 PTFE tubing https://www.seemecnc.com/collections/pa ... d-x-4mm-od
OR worst case scenario
$65 Bowden Hotend https://www.seemecnc.com/collections/pa ... den-hotend
~$20 -$65 and 2 hours of work?
So what do you think, is it worth it do upgrades on the older system for better printing, or save the cash and time to buy a V3 later?
OR
My 3 objectives are
