Poor 1st Layer Adhesion Between X & Z
Posted: Wed Feb 22, 2017 2:39 pm
				I recently completed my v1 to v3 conversion and am amazed at how much better the entire build process and final product is in just 3 short years.
For the first time since I bought my v1 in 2013 have I been able to print the 265mm circular test print with decent results. However I am still getting issues between the X and Z tower. For example if I print the test pattern the nominal thickness of the print is around 0.30mm but between X and Z (from 7 to 10, if Z tower is 12) the thickness increases to 0.42mm to 0.46mm but this effect is not mirrored to the same degree 180degrees apart. The opposit side of the bed (from 1 to 4) is only reduced from 0.3mm to around 0.28mm.
I have verified my bed is flat at 20C and 80C, my endstop offsets are (1,2,1), my Horizontal radius is 143.62, and my diagonal rod length is still stock. All other settings are still stock. I have ran G29 about 10'times to get my offsets dialed in but didn't use the online calibration as it previously changed my arm lengths and required a change of over 1.0 to my horizontal radius. And even after that I still had the same issue. I have also measured my tower lean with X and Y being less than 0.2mm off at the top and Z being about 0.65mm tilted in at the top.
Any advise would be greatly appreciated!
