Motors not working
Posted: Tue Mar 21, 2017 7:16 pm
				I have a Rostock MAx V3.
I recently had a thermal fuse blow. While I was trying to diagnose the problem I think I created a new problem.
I have fixed the thermal fuse and the HE280 is now functioning properly.
While I was trying to diagnose the problem, I first took out all the connections to the Rambo and took it out and examined it.
I replaced all the wiring per SeeMeCNC guides.
I reinstalled the firmware.
THe problem I am having now is none of the motors are working.
I checked the F2 fuse and it's working. I even swapped the F2 and F3 fuses with each other just to be sure.
Any ideas? what could cause all the motors to stop functioning other than the fuse.
David
David
