Thermal Fuse blowing 2x row
Posted: Fri Mar 31, 2017 8:19 am
				Guys,
I have a Rostock Max v3 with HE280.
I recently ran into a problem which I correctly identified was my thermal fuse.
http://forum.seemecnc.com/viewtopic.php?f=37&t=11772
I just replaced my thermal fuse and made another minor tweak and got it working again.
During my first print after the repair, my replacement thermal fuse blew. I took apart the HE280 again and verified it's the thermal fuse again.
I am going to replace the second thermal fuse -- but has any experience with multiple thermal fuses blowing consecutively? Should I cinsider this unusual or a pattern of something else? I am suspicious that I am losing thermal fuses to some incorrect configuration or something or the root cause is elsewhere ????
Previously I had been using PLA (printing successfully at hotend "210") and switched to ABS these are the first runs of my machine at a higher temp hotend "235".
Any ideas from the Forum?
Any ideas would be appreciated.
