Trouble uploading firmware
Posted: Fri Mar 31, 2017 11:32 am
by corranthrn
Hello,
I think I've cocked up somewhere. I tried to upload a pre-compiled firmware (compiled in Arduino), and now the board will no longer reply to programming requests.
The green light is on, there is a yellow light flashing very fast, and the Rx light also blinks. I'm at a loss for what to do next. just keeps telling me that the programmer is not responding to the messages.
Arduino: 1.8.2 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 137510 bytes (54%) of program storage space. Maximum is 253952 bytes.
Global variables use 7447 bytes (90%) of dynamic memory, leaving 745 bytes for local variables. Maximum is 8192 bytes.
Low memory available, stability problems may occur.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM16 -b115200 -D -Uflash:w:C:\Users\SEANTA~1\AppData\Local\Temp\arduino_build_737704/Repetier_edited.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM16
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Wiring
         Description     : Wiring
         Programmer Model: AVRISP
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
An error occurred while uploading the sketch
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Re: Trouble uploading firmware
Posted: Sat Apr 01, 2017 9:10 pm
by Eric
Try pressing the reset button on the rambo right after the avrdude command.
Posted: Sat Apr 01, 2017 10:31 pm
by corranthrn
I emailed Support on this issue and JJ suggested disconnecting the accelerometer and trying to upload again. I did that, and also didn't click the rear power button on until I was actually clicking upload at the same time. The reset button wasn't working for what people kept suggesting.
Part of the initial problem is that I had partially flashed a firmware+bootloader file and corrupted part of the bootloader which caused a series of other problems. I re-flashed it with a firmware+bootloader and it worked.
