PEEK hot end failing
Posted: Wed Apr 05, 2017 9:12 am
I put our Rostock Max V2 together over a year ago and am now experiencing some issues with the hot end. Everything was previously working just fine. I was just wondering if others out there had experienced similar issues.
The problem seems to be that at least one of the heating resistors is failing or completely gone. The hot end will try to reach the target temp, but doesn't seem able to get past ~200 C. I measured an approximate 10.5V voltage drop while the unit is heating across the resistors, which I assume is expected, and saw that the resistance was >7 ohms. (My multimeter is pretty crappy, the leads themselves will often measure ~3 ohms.) Since they are in parallel, the resistance should be around 3.5 ohms, right?
Based on this troubleshooting, I've already ordered new resistors (and spares) along with a new thermistor, just in case I wreck the current one while replacing the resistors. I guess I will also need new crimp connectors for the resistors. Any idea where the best place to get those would be, as in an actual store? Home Depot? Or local electrical supply?
Anyone else already done this and have some hints on a successful hot end repair?
Thanks in advance,
-rick
Thanks in advance,
-rick
