Bondtech Extruder Occasional Clicking
Posted: Sat Apr 22, 2017 10:56 am
ok I have finally got the printer up and running. The only lingering problem i Just can't seem to get ironed out is the extruder clicking every now and then. I included a copy of my config file. I have a Bondtech QR extruder. I have tried adjusting the steps but it didn't seem to do anything. Any Ideas?
TIA
Ricky
Configuration file for dc42 Kossel
; Communication and general
M111 S0 ; Debug off
M550 ; Machine name (can be anything you like)
M551 ; Machine password (used for FTP)
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0x42 ; MAC Address
;*** Adjust the IP address and gateway in the following 2 lines to suit your network
M552 P0.0.0.0 ; IP address (0 = use DHCP)
M554 ; Gateway
M553 P255.255.255.0 ; Netmask
M555 P2 ; Set output to look like Marlin
M575 P1 B57600 S1 ; Set auxiliary serial port baud rate and require checksum (for PanelDue)
; Axis and motor configuration
M569 P0 S1 ; Drive 0 goes forwards
M569 P1 S1 ; Drive 1 goes forwards
M569 P2 S1 ; Drive 2 goes forwards
M569 P3 S1 ; Drive 3 goes backwards
M569 P4 S1 ; Drive 4 goes backwards
M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
M665 R144.378 L291.060 H330.915 B140.0 X0.335 Y0.174 Z0.00 ; set delta radius, diagonal rod length, printable radius, homed height and XY tower corrections
M666 X0.10 Y0.16 Z-0.26 ; put your endstop adjustments here, or use auto calibration to find them
M92 X80 Y80 Z80 ; Set axis steps/mm (20 tooth pulleys, 0.9deg/step motors)
M906 X1000 Y1000 Z1000 E1200 I40 ; Set motor currents (mA)
M201 X3000 Y3000 Z3000 E1000 ; Accelerations (mm/s^2)
M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes
G21 ; Work in millimetres
G90 ; Send absolute coordinates...
M83 ; ...but relative extruder moves
; Thermistors and heaters
M305 P0 T100000 B3950 R4700 H0 L0 ; Typical Chinese bed thermistor. Put your own H and/or L values here to set the bed thermistor ADC correction.
M305 P1 T100000 B4388 R4700 H0 L0 ; E3Dv6 hot end. Put your own H and/or L values here if necessary to set the first nozzle thermistor ADC correction.
M301 H0 P20 I0.5 D1000 T0.85 W150 B5 ; PID settings for the bed
M301 H1 P10 I0.10 D100 T0.50 ; PID settings for extruder 0
M307 H1 A426.7 C196.3 D11.5 B0
M570 S200 ; Allow extra heating time
; Tool definitions
M563 P0 D0 H1 ; Define tool 0
G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
M92 E460.83 ; Set extruder steps per mm for first and second extruders
; Z probe and compensation definition
M558 P1 X0 Y0 Z1.0 H20 F300 T12000 ; Z probe is IR and is not used for homing any axes, Z probe dive height 3mm, probing speed 300mm/min, travel speed 12000mm/min
G31 X0 Y0 Z0.42 P500 ; Set the zprobe offset and threshold (put your own values here). For a delta, use zero X and Y offset.
;*** If you are using axis compensation, put the figures in the following command
M556 S78 X0 Y0 Z0 ; Axis compensation here
M207 S7.0 F3600 Z0.1 ; Set firmware retraction details
M572 D0 S0.1 ; set pressure advance
T0 ; select first print head
Edit: to add config text.
TIA
Ricky
M111 S0 ; Debug off
M554 ; Gateway
; Tool definitions
