FSR Calibration with the Duet Wifi
Posted: Sun Jun 04, 2017 2:13 am
I have a Rostock Max v3 with FSR probing, the Trick Laser FSR plate, and the Duet Wifi board.
I am trying to do a large (230 mm widest) print and am consistently having the first layer around the perimeter not adhere at all. Small prints (~ 50 mm widest) adhere perfectly. The bed is the stock glass on Trick Laser's heat spreader, held down at three points. The only thing on the glass is hair spray (PEI coming soon). It is clear to me that the issue is the Z height is too high.
I am running the Duet's 13 point configuration and getting the same Z height every time. What is confusing me is I am going into the config-override.g file and increasing the Z height, restarting the Duet, and it doesn't seem to do a thing. The Z height is still too high and so there is no adhesion. Perhaps I am missing something about how this works.
Also, does Duet's 13 point 6 factor calibration set the delta radius or do I have to?
I appreciate any help.
Update: I just checked the height of the nozzle above the bed at Z0 and it is about 3 mm too high. This is after doing Duet's calibration.Checked the bed and it is flat.
