Power supply smoking :)
Posted: Fri Jun 23, 2017 12:50 am
Hey,
I have a RMax v3 kit
Today I fired up my printer for the first time in about a month, and was going to start using it again. It took "forever" to heat up before printing. (like 20+ minutes) then went it got to the designated temperature 210 noz/60 base the lcd read out simply said "def" for both temperatures and started to cool down. I tried to use it again after resetting and letting cold down, but it started to smell pretty bad, and I turned it off and picked up the Onyx heating bed and started to look, for what went wrong. After looking for a moment, I noticed smoke coming from the fan holes on the power supply.
I tried checking the top of the unit and the heating bed for any signs of a short that could do that, and I didn't see anything "obvious".
I assume I'll be ordering a new power supply at the least. But I could really use some help tracking down or testing to make sure I don't blow it out when I plug that in. Where should I start?
Thanks much.
Thanks much.
