Panel due not working (both USB to PC and ribbon to duet)
chuyuanver
Post by chuyuanver »
It was during an electronic debug and upgrade that the panel due stops working. (I didn't notice when until I finished both) I was having a fan problem due to the short in always on fans. According to suggestions from this forum, I connected the V_IN of V FAN JUMPER SELECT to V_IN of POWER IN using a wire on the back of the board. Also, there is jumper already in V FAN JUMPER SELECT connecting V_IN and V_FAN. Now the fans work properly.
The next thing I did is installing a FSR sensor. I used the kit from ultibots and connected the JohnSL board to the E0 stop. It works fine from what I observed.
But then I turned everything on and find that the Panel Due is pitch black. I am not sure what has happened so I tried to connect the board to PC to test the board. Then I found out that my PC isn't recognizing the board at all. I have installed the latest version of arduino IDE on my computer. Is there any idea what I should do with it now?
dc42
Re: Panel due not working (both USB to PC and ribbon to duet)
Post by dc42 »
I believe you have posted a similar question on the duet3d forum, and I have replied there.
