Rostock MAX v3 Crash with Dual Extrusion
Posted: Sun Oct 08, 2017 10:47 am
				I have a Rostock MAX v3 equipped with the dual-extrusion Y-Adapter.
The currently firmware is 0.92.2 (20170822)
The only change to configuration.h is specifying that the the printer is equipped with the y-adapter (#define NUM_EXTRUDER = 2)
Whether I am using Mattercontrol of sliced gcode from Simplify3D, when the machine needs to switch filament it retracts E0 properly but then crashes and becomes non-responsive before engaging E1. By all accounts E1 appears to be properly installed. Additionally, when I "home all" the machine homes then locks up as well. This is the second RAMBo and LCD controller I've had installed, the previous unit experienced random lock ups.
I have not added any tool change code to Mattercontrol of S3D, I could not determine if it would be necessary.
I can print fine while only using a single extruder.
Summary of actions: Clear EEPROM, flash firmware (almost completely straight from GitHub), calibrate, print, lock up.
Any help would be greatly appreciated, thank you.
