I have been trying to print the spool holder Tube, it's about five layers in and then stops. The hot end is embedded in the work It won't lgo any farther it's happened three times in the same spot.
Help!
Prinlter stops At the same spot
- pouncingiguana
Re: Prinlter stops At the same spot
Gonna need some more information to help you. Are you printing from the SD Card or from a computer over the USB? What did you slice it in? Can you post your gcode so we can take a look?
