RostockV2 hot end won't heat past 145C
Posted: Sat Nov 11, 2017 4:16 pm
I have an essentially stock Rostock V2, with the old hot end. A few days ago, the last print was printing ABS at 220C. Today, I cannot get the hot end to heat past 140-145C.Watching the temp rise, it appears to act as if the set point was in the 140-145C range. That is, the temp rises more slowly as it approaches 140C, eventually plateauing out. It will stay at this temperature for several minutes, but will eventually start displaying "def" for both hot end and bed temps, and the bottom line of the display reads "Heater decoupled".
My research here makes me believe that the software has detected (correctly) that the hot end is not responding properly, and has shut the power to both hot end and bed down.
The thermistor seems to be behaving normally. I don't see any strange, out of range values (0 or 300C); it just never gets up to temp.
I tried the hot end PID tuning routine; it timed out, with the temp once again only making it to the ~140C range.
Could one of the heater resistors have died? This just occurred to me, and may be the case. I just now removed the hot end power wires from the RAMBO board. From that point, I am reading 9.2 Ohms. If the resistors are supposed to be 6.8 Ohms, with the two in parallel, the heater resistance should only be 3.4 Ohms. I don' t know where the other ~2.5 ohms is coming from. Nonetheless, this is a likely possibility.
I'd be happy to hear any other ideas as to what might be going wrong.
