Interesting symptom of an over-tightened carriage
Posted: Sun Dec 10, 2017 3:37 pm
I thought people might find this interesting.
My Orion has the old-style wood cheapskate carriages. I recently adjusted the wheel cams, and noticed a faint parabolic pattern artifact on cylindrical objects. It was only noticeable when using an overhead light source.
The parabola seemed to either peak or bottom out just opposite the Z tower, so I checked it, and apparently the wheels were a bit too tight.
I loosened them a bit and the pattern went away. The best setting seems to be where it only requires moderate finger pressure to make the wheels slip against the tower.
I can only imagine that over-tightening caused some kind of deformation of the wheels. Kind of like when you get a grocery cart with a bad wheel. Fortunately, it does not appear to have caused permanent damage to the wheels.
