Keep needing higher and higher temp settings. Max V2
Posted: Sat Jan 13, 2018 7:09 pm
Was also covering this in my build thread, but trying here as well. At my wits end, been fighting this for months.
Basically, I keep having to increase the temp in my hot end, in order to print. For a few years I had been consistently printing in the 225-230c range. Then, this summer, I started to get some clogs. Eventually I discovered I needed to set my temp to 245c just to get anything to extrude. So I started printing at 245c while trying to find what's going on. Now even 245c isn't enough, tried 270c and still not enough. Finally I had to set my output at 290c just to get anything to extrude and print. I doubt this is correct, but I don't have a way to calibrate it right now. And whatever is happening, keeps getting worse over time anyway, because I keep having to raise the temp to print.
.4mm nozzles at this point are impossible to use, they just clog almost instantly. .8mm works for a while till I have to raise the temp again.
The temp indicated by the thermistor always matches what I set it to, so it's not like a heater that can't keep up, that would indicate a lower temp than expected. No matter what I set the temp to, It'll warm/cool to that temp.
Printer Specs
Rostock Max V2 running firmware 0.92.2 (had an earlier version when this started, since updated)
E3D V6 hot end, with new 'block and sock' upgrade to a cartridge thermistor.
RAMBO board.
Things I've tried to solve this problem, with no success.....
Updated firmware
Installed new thermistor, then updated to the newer style thermistor and heater block.
New nozzles. Many attempts.
Checked that all wiring connections are good.
Could use any suggestions you guys have on this.
Printer Specs
RAMBO board.
Updated firmware
