I2C pins
Posted: Fri Mar 01, 2013 12:02 am
by cambo3d
can someone tell me if their rambo 1.1 version has an I2C connector.
If not what would be good connector to place here? links to it. What's it called?
Looks like I could probably use the same type of connectors that connect the stepper motors. What are those called?
[img]
http://reprap.org/mediawiki/images/5/5c ... nn-all.jpg[/img]
Re: I2C pins
Posted: Fri Mar 01, 2013 9:18 am
by gabrielk
According to this
http://reprap.org/mediawiki/images/7/75 ... ematic.png
SDA is on Pin 20
SCL is on Pin 21
just like in Arduino Mega
in the bottom right corner you have schematic of I2C
I have 1.0 and i also have only spots for soldering.
Just curious, what you want controll by it, and by what?
Re: I2C pins
Posted: Fri Mar 01, 2013 9:29 am
by gabrielk
Re: I2C pins
Posted: Fri Mar 01, 2013 11:24 am
by cambo3d
Planning my build and I have an lcd control panel coming that is wired through I2C.
http://www.panucatt.com/product_p/vikilcd.htm
Looking at the configuration for marlin. It looks like it has the files to support it. This works with the ramps and arduino combo as plug and play so I'm hoping it will be the same for the Rambo.
Re: I2C pins
Posted: Tue Dec 10, 2013 5:04 pm
by Maco
Hi i want to know if its possible to extend the capability of the rambo via I2C to control 2 more extruders, Im looking to control this beast
http://e3d-online.com/The-Kraken
I see some pwm extension and more extension capabilities for the rambo just want to be sure if I can use the kraken with this boars
Thankss
Re: I2C pins
Posted: Tue Dec 10, 2013 5:54 pm
Maco wrote:Hi i want to know if its possible to extend the capability of the rambo via I2C to control 2 more extruders, Im looking to control this beast
Thankss
Here are three topics that discuss the E3D and the Kraken, perhaps you can join one of these discussions.
http://forum.seemecnc.com/viewtopic.php?f=54&t=3714
http://forum.seemecnc.com/viewtopic.php ... 2&start=60
http://forum.seemecnc.com/viewtopic.php ... 7&start=10
Re: I2C pins
Posted: Wed Dec 11, 2013 1:24 pm
by Maco
Re: I2C pins
Posted: Mon Jan 20, 2014 5:15 pm
by bubbasnow
here is a pwm shield that works with i2c
http://www.adafruit.com/products/815
