Weak first layer extrusion, jams mid print.
Posted: Fri Feb 02, 2018 6:41 pm
After completing my upgrade to the duet wifi, fsr setup and titan extruder i still havent managed a successful print. Calibrated esteps, auto calibration and bed mesh compensation.
During the upgrade i followed mhackneys guide on his sublimelayers blog, used the firmware files he supplied but hopefully changed them to fit my max v2.
Now to my current issue. When i go to print my first layer seems to be under extruding. Ive adjusted the zprobe offset with no change to the first layer extrusion. If i turn the extrusion multiplier up to 120% it looks around what i would expect. After the first 2 layers i change it back to 100% and let the print continue. After a few layers it seems like my hotend jams.
Does anyone have any ideas of what the problem could be? Im new to the reprap firmware so i could be missing something. I can post my config.g and bed.g if that helps.
Dan
Dan
