PCB Board Rev 6a
Posted: Wed Feb 14, 2018 10:13 am
by Morriz
Anyone has PCB Board Rev 6a schema?
Pin voltage / use?
Thank you,
Marcello
Re: PCB Board Rev 6a
Posted: Wed Feb 14, 2018 10:38 pm
Can you clarify what "rev 6a" pcb you're talking about? :)
Posted: Thu Feb 15, 2018 4:53 am
by Morriz
This one:
https://www.seemecnc.com/collections/pa ... -pcb-board
that is different from rev 5a schemes on GitHub site.
Posted: Thu Feb 15, 2018 8:23 am
Posted: Thu Feb 15, 2018 8:36 am
by Morriz
I saw that on new Rev 6A of PCB there're new 2 pins socks named PROBE, LED and 3 FAN PART than 1.
What is the use of PROBE? Voltage In/out?
Voltage Out of LED? Always ON?
Thanks,
Marcello
Posted: Fri Feb 16, 2018 4:15 pm
I'm not sure what the changes are related to - I don't have one of the newer boards.
Posted: Sat Feb 17, 2018 3:48 pm
by pouncingiguana
The probe pin locations are not used.
The LED pins are always on hooked to the main power for the hot end (nom 12v always on).
The three part fans are wired in parallel with each other.
The Heatsink fan is wired to the hot end main power (always on)
Posted: Tue Feb 20, 2018 4:39 am
by Morriz
Thank you pouncingiguana
Marcello
