Rmax v.2 CURA?
Posted: Sun Feb 25, 2018 11:07 am
by Outsider
Will SeeMeeCNC be also releasing a CURA profile for older machines. ie:RMAx ver.2 ?
Re: Rmax v.2 CURA?
Posted: Sun Feb 25, 2018 3:56 pm
The Cura profiles are more based on the hot end and max travel speeds.
If you've got a v2 with the old 2-resistor style hot end, you can use the HE280 profile and tune the retract length & speed from there. The max travel speed should already be ok as all the HE280 equipped printers also use the RAMBo board, which is the final arbiter of max travel speed.
The old hot end design liked long & fast retracts - between 3-6mm retract and 50-100mm/sec retract speed. If you've got a well tuned profile for your existing slicer, I'd use the retract values you've established as a starting point with Cura.
Re: Rmax v.2 CURA?
Posted: Sun Feb 25, 2018 6:12 pm
by Outsider
good to know. Thanks
