				New Artemis, Homing and calibration issues
				Posted: Tue Feb 27, 2018 2:50 am
				by Noircogi
				I got my Artemis today and assembled it.  I already have a Max3 which I built as well.
There is an issue with the X tower.  When I select "home" from the web interface, sometimes it works, and sometimes it moves the X carriage way down then back up.  When it does work, the X carriage is about 3/4 of an inch from the top after homing, but Y and Z are very near the limit switch.
If I manually move the carriage or touch the limit switches, I see the LEDs for the limit switches go out for each one, including X.
If I try to run the "First Probe" macro, it will eventually get confused and start reporting errors.  The steppers all seem to be running smoothly and the X limit switch appears to be working OK as well.
Any suggestions what the problem might be?
The biggest hint is the X carriage going way down during homing, why would it do that?  It's almost like the X direction is reversed, but it doesn't behave consistently that way.
				Re: New Artemis, Homing and calibration issues
				Posted: Tue Feb 27, 2018 8:48 am
				I would carefully examine the stepper connector for the X axis.  Make sure the crimps are good and that the socket is fully seated in the connector shell.
The behavior you describe screams "intermittent connection".
				Posted: Tue Feb 27, 2018 8:57 am
				by wepollock
				To debug the problem (were it me) I would;
1) unhook the arms and the effector before going further; so I could safely test w/o having to worry about crashing the effector into the bed.
2) check to make sure that the stepper motor wires are seated..  <- I see gene got that covered... (we were posting at the same time lol)
Yeah that is the first thing I would check.
3) Compare the wires to make sure they are in the correct color order.
4) switch axis (x) to axis (y) and vise versa - the problem should migrate from the x to y axis.
--I don't think your problem is below (but I would still check it out - because it is easy to do)
In the web interface you can go to
Settings->Machine Properties - you can test the endstops by manually pressing them; you will see the result on the web interface..
You can also go to settings: system editor; and check out  homedelta.g
G91                         ; use relative positioning
G1 S1 X750 Y750 Z750 F5000  ; move all carriages up, stopping at the endstops
G1 S2 X-5 Y-5 Z-5 F500     ; move all towers down 5mm
G1 S1 X8 Y8 Z8 F500        ; move towers slowly up 8mm, stopping at the endstops
G1 S2 X-5 Y-5 Z-5 F500     ; move carriages down 5mm
G90                         ; back to absolute positioning
To confirm you are homing on the Duet web interface - a misconfigured slicer might home improperly as described.
				Posted: Tue Feb 27, 2018 2:49 pm
				by Noircogi
				Gene was right.  Intermittent connection  on the X stepper motor.  I had to disconnect and reconnect it a couple of times to get it solid.  Perhaps there was some oxidation on the pins. Homing and calibration work fine now.
This morning I was able to get that going and verify the  bed heater and thermistor are working.  Tonight after work I will move on to the rest of the checkout.
				Posted: Tue Feb 27, 2018 2:52 pm
				\o/
				Posted: Tue Feb 27, 2018 9:09 pm
				by Noircogi
				Turns out it was still flakey.  I ended up cutting the connector off and using a few of the spare pins to re-do it.  There must have been a bad crimp in the factory-supplied set.  It's now happily printing the pre-sliced benchy with the supplied neon green PLA and all looks  good.
				Posted: Wed Feb 28, 2018 1:00 am
				by adarcher
				Glad you got it all working!
The pins also have a little tab to keep them in.  When I had the same problem, I saw that I had to use a knife to bend them back out so they'd "snap" into place again.
Post a pic of your benchy when it's done
