print problem, printing a spinning top with tower top, tower comes out wrong
Posted: Tue Feb 27, 2018 9:13 am
by magicmarc
hi, the base of the spining top prints right, then it gets to the tower part, and after a short bit the print screws up, as shown in the picture.
this is standard pla, 0.2 layer, 20 % infill (i also tried 15% same thing happens) i also tried different temps, 210, 215, 220, etc.. same hting happens..
any ideas?
thanks all.
Re: print problem, printing a spinning top with tower top, tower comes out wrong
Posted: Tue Feb 27, 2018 12:19 pm
by Mac The Knife
The printer needs to slow down when in is printing that detail. Or you need more cooling
Posted: Tue Feb 27, 2018 12:54 pm
Yep. Too hot, too fast, or both.
Posted: Tue Feb 27, 2018 2:44 pm
by magicmarc
thanks everyone, im going to slow it down now, and cool it down, with temp and fans.
thx
marc
Posted: Tue Feb 27, 2018 2:53 pm
You might want to look into the minimum layer time of whatever slicer you use. That will guarantee it'll slow down as it prints the center of the top.
Posted: Thu Mar 01, 2018 8:38 am
by magicmarc
im using mattercontrol to slice and print to h2 hacker.
im having error using cura to slice and mattrercontrol to upload gcode and print, the gcode generated from cura looks and is wrong when added to the que in mattercontrol.
Posted: Thu Mar 01, 2018 8:45 am
I can just about guarantee there's nothing wrong with Cura if you've got it configured properly. I can't say the same for MatterControl.
My advice is to slice on Cura and either print via SD card or use a Raspberry Pi & Octoprint.
Posted: Thu Mar 01, 2018 12:57 pm
by magicmarc
THAKNS AS ALWAYS GENE AND EVERYONE. I WILL TRY THE SD CARD PRINT TODAY/TONIGHT.
AS WELL IS THERE A GOOD YOUTUBE LINK OR INSTRUCTIONS TO USE OCTOPRINT?
THANKS
