Help with leveling
maxx
Help with leveling
Post by maxx »
Dear forum, I did try my best to get this beast running and finally i got all my outper parts of the onyx level but the center is reasonable higher. I don't find the proper parameter in the repetier FW which should fix that. I read that DELTA_RADIUS should help but to my understanding there is no parameter for belt driven delta bots like the Rostock max.
So how can i lower the center without affecting the outer locations? Its a massive difference 0.5mm is rather large.
Greetings
Max
aehM_Key
Re: Help with leveling
Post by aehM_Key »
Add or subtract a value to DELTA_RADIUS. It will actually change the outer levels, without influencing the center one ;)
Make sure you do the calibration with hot bed and heated hot end.
