Wire Connectors for Accelerometer Board
Posted: Tue Apr 10, 2018 7:13 pm
by wheemzy
I've burned through two accelerometer boards and I want the third to really last.
What are the best wire connectors to use for the hot end and thermistor wiring?
I looked into using screw terminal connectors but they only seem to come in two pins or more, but not one pin.
Since the holes for the hot end leads are so far apart, the two pin connectors won't work.
Thanks,
Matthew
Re: Terminal Connectors for Accelerometer Board
Posted: Wed Apr 11, 2018 2:14 pm
They're uninsulated, so you'd be wise to wrap them in Kapton, but I've used "knarps" from the BMX store before. They're the adjustable ball end from a bike brake cable.
[img]http://sheldonbrown.com/harris/images/knarps.jpg[/img]
[img]http://i.imgur.com/xjXbato.png[/img]
Posted: Wed Apr 11, 2018 8:08 pm
by wheemzy
well that's certainly a creative solution. :D
Was thinking of using pin connectors for the thermistors....
https://www.amazon.com/Hilitchi-2-54mm- ... connectors
I guess something like these would work for the heater cartridge.
https://www.amazon.com/AUSPA-Lever-Nut- ... connectors
Any particular reason you choose the knarps parts?
Cheers,
Matt
