Calibration Nightmare
Posted: Sun Jun 24, 2018 8:32 pm
				I'm not even sure where to start. . .
I bought my V2 years ago, and as with most people, went through the usual learning curve. I learned to manually calibrate and set it up (not a complex task i felt) and was printing decently with ABS. I had to babysit it a lot and had a print failure rate of about 60 percent. I eventually upgraded to PEI and the injection molded carriages and ball arms. I also move to an e3d V6 with .4mm nozzle all mounted on one of 713 makers' mounts with a yellow-jacket board. My biggest issue was getting it to hold temp some of the time and having PID calibration wanting to go cookoo all the time. I was getting to a point where I was usually successful, loosing only about 1 in 3 prints.
Life got in the way as it tends too, and the printer sat untouched for a year and a half. I recently got the spark back and decided to completely overhaul the wiring. Once I got done rebuilding, I ran temp calibrations and I was super happy with how stable and quickly it reached and maintained temp settings. Then I went to actually print something. . .
I printed one single layer circle to check for level, and while it didn't fail entirely it wasn't amazing. Since that circle I haven't been able to print anything. Using the same filament again, it just spit out dots on the bed and wouldn't start to really put out anything. I figured it was the old filament, so I changed to a new roll of abs. same problem, i couldn't get a first layer down. I decided to clean out the hot end and try again, and no luck. I went back and completely re-calibrated and leveled. Still no go. So then I decided to switch to PETG for the first time, because i figured why not. It just rolled around the nozzle and made a mess. Lowered my Z and tried again, same problem. I adjusted until my Z was basically zero and still nothing stuck. With everyone talking about how their prints always stick to PETG too well, I'm really confused. Decided to switch out nozzles for a new .5mm and still no change.
Lastly I went for broke and flipped the bed over to bare glass. re-calibrated and went for it. Still not a single thing. I had one potential moment where a half inch path of a perimeter stuck for a few seconds only to get yanked up by the building mass of goop on the nozzle.
I'm about to chuck this machine at a wall! Please, anything that could help I'd be willing to listen.
