V3.2 Carbon Fiber Rod upgrade
Posted: Fri Nov 23, 2018 8:21 pm
by cloneit3d
I just added the carbon rods to my V3.2, along with the aluminum ball joints and despite updated the rod length in config.g I can't get the hot end from severely crashing into the bed. Maybe the homed height has to be adjusted? To maybe 350.56 instead of 400?
Here is what my config.g file looks - one line I adjusted-
M665 R144 L340.5 B135 H400 X0 Y0 Z0 ; delta radius, diagonal rod length, printable radius and homed height
; Y X Z are tower angle offsets
From the Carbon Fiber part this note is at the bottom of the page-
Note: The configuration file (Duet config.g) must be updated with the proper diagonal rod length.
I cannot seem to find anything on the site that tells me what I am doing wrong. I am sure it is something very obvious. Thanks in advance for any assistance.
Tim
Re: V3.2 Carbon Fiber Rod upgrade
Posted: Sat Nov 24, 2018 10:52 am
Did you delete config-override.g? You need to do that and then re-run first calibration. (If you created a bed map, delete and re-create that as well.)
Posted: Sun Nov 25, 2018 4:49 pm
by dc42
As well as deleting config-override.g, increase the dive height (H parameter in the M558 command) to e.g. 30 until you have it calibrated. That allows more tolerance for the homed height and delta radius not being set accurately. Changing the rod length will have changed the homed height.
Posted: Wed Nov 28, 2018 4:47 am
by artexmg
For Artemis, I ended up modifying the printer height instead of the dive height for Z probe. the Artemis gains about 10mm in Z with this new arms.
Posted: Wed Nov 28, 2018 9:32 pm
by cloneit3d
Thanks for all of the tips- I started with all new firmware and made two modification to config.g
Diagonal road length was changed to 340.5 and the home height was changed to 350.56.
M665 R144 L340.5 B135 H350.56 X0 Y0 Z0 ; delta radius, diagonal rod length, printable radius and homed height
Posted: Mon Dec 03, 2018 2:21 pm
by artexmg
Yes, I forgot to mention, but the height has to be modified as well, otherwise the nozzle falls short to touch the bed.
Just one question, are this values for the Artemis? I'm curious because mine has different values for Delta radius (R=150) and printable radius (B=145).
Posted: Mon Dec 03, 2018 2:29 pm
by artexmg
artexmg wrote:Yes, I forgot to mention, but the height has to be modified as well, otherwise the nozzle falls short to touch the bed.
Oh, never mind, this is V3.2 :-)
Posted: Tue Dec 04, 2018 9:01 am
The carbon fiber arms work on both the v3.2 (or 3!) and the Artemis.
Posted: Thu Dec 06, 2018 11:28 pm
by artexmg
Yes, they're working fine in my Artemis. My mistake was to think that the Delta Radius and Printable Radius cloneit3d mentioned were for Artemis, while he was talking about a V3.2.
Posted: Mon Jan 07, 2019 9:33 pm
by Horvaticus
Just wanted to chime in here - what are the advantages of a carbon fiber arm? Some musings on Sublime Layers informs me that backlash is reduced, sounds like it increases quality when printing at higher speeds?
Posted: Wed Apr 22, 2020 5:17 am
by artexmg
Haven't been in the forum for a while, just seeing your post, sorry about that!
I have increased quality of prints in general, I do not go over 55-60 mm/s
