Appearance of Parts Tapering with Z-Height
Posted: Thu Jan 17, 2019 9:29 am
by MobiusOne
Good morning SeeMeCNC Community!
I just had a quick question. Has anyone ever experienced a print tapering in ever so slightly as they increase in Z-height? I printed a model that is quite long and cut into about 4 or 5 pieces along the length and it seems like the ends aren't matching up accurately. The top of one piece is just slightly smaller than the bottom of the other piece. There is no elephant's foot occurring which I thought might be the initial case. I'm wondering if it's a scaling issue but that would make sense if both ends were seeing the same thing, not just one end. It's very minor but it's enough that they don't line up and you can tell! Any thoughts would be great, but it's not stopping me from printing in general right now so I'm in no immediate rush to get it taken care of. Just looking to see if anyone else has experienced something similar! I plan to do a scaling change using M579 to see if that helps but otherwise, I'm just rolling with it as is.
Model: Rostock Max V2
Upgrades: DuetWifi, FSR leveling, Carbon rods, 7" Duet Screen, E3D-V6 hot end, new but original carriages, aluminum CNC milled ball joints.
Re: Appearance of Parts Tapering with Z-Height
Posted: Fri Jan 18, 2019 11:02 am
by rootboy
I think that if you go down one post in the forum you will get your answer.
http://forum.seemecnc.com/viewtopic.php ... 702156d4a1
But to answer your question, yes, mine gets off noticeably in the X & Y axises, but Z is slightly affected as well.
