[SOLVED] Frustrated! Issues with vertical dimensional accuracy and layer shifting on first 5mm of layers
Posted: Sun Mar 24, 2019 3:50 pm
by Thefruitypotato
I've been having a VERY strange issue with my Rostock Max V2 recently, the vertical dimensions are stretched and the first few layers are shifting in one direction. All of this after calibrating the bed as perfectly as possible?
- Left = Maker Select Mini Right = Rostock Max V2
I have tried:
Arm length calibration
Steps/mm calibration
Bed leveling
Different slicers
I am using:
Mattercontrol (latest)
Cura (latest)
Photo of printer (don't worry I'll patch those exposed wires
Re: Frustrated! Issues with vertical dimensional accuracy and layer shifting on first 5mm of layers
Posted: Mon Mar 25, 2019 3:10 am
by dc42
A long shot, but are you using steel cored belts? The steel cores fracture, which causes this type of problem.
Posted: Mon Mar 25, 2019 8:17 am
I would check to make sure that you don't have a loose drive gear, or a carriage that is dragging - maybe a failed bearing?
dc42, to my knowledge, SeeMeCNC has never supplied steel core belts, but it's interesting to know that's a failure mode of that belt type.
tnx.
Posted: Mon Mar 25, 2019 8:09 pm
by Thefruitypotato
SOLVED!
I did:
Re-install firmware (Use Arduino IDE 1.6.0)
Find your proper delta dimensions in Configuration.h (updated config is very different from original for V2)
Upload and you're done!
Thank you for all the help!
Re: [SOLVED] Frustrated! Issues with vertical dimensional accuracy and layer shifting on first 5mm of layers
Posted: Tue Mar 26, 2019 8:22 am
\o/
