Hey Guys,
New to the forum and the family. Purchased an Artemis this week because Deltas are cool and I wanted one.
Given the massive print volume, a filament runout sensor seems to make sense. Has anyone dabbled with adding a run-out sensor to their Artemis? Seems doable with the duet.
Looking for any wisdom or advice for those who have already tackled this issue.
Thanks,
D
Artemis with Duet Filament Runout Sensor
- Plasticator
Re: Artemis with Duet Filament Runout Sensor
You want to buy one of these : https://www.amazon.com/dp/B07JJ2835X/
Instructions are here:
https://duet3d.dozuki.com/Wiki/Connecti ... NT7jwfg7Pw
To give you a hint, the M591 command goes into your config.g file and you want it to trigger a pause.g
Seemecnc should really make this anoption on their printers.
Also see duet sells a “laser” filament detector too....
https://www.duet3d.com/DuetAddons/LaserFilamentMonitor
Instructions are here: https://duet3d.dozuki.com/Wiki/Duet3dFi ... serVersion
For £25, I might have to try it.
- Plasticator
Awesome! Thanks for the reply.
