Extrude is choppy - broken into segments and not complete.
hcdbey
Post by hcdbey »
Rostock Max V2.
MatterControl 1.7.5
Previously, when I would select a manual 10 mm extrude, it would extrude for about 5 seconds and I would get 10 mm. Now, it is very inconsistent.
If I now select 10 mm, it may extrude 1 or 2 mm pause and then extrude a few more millimeters but not enough to make 10 mm.
Similarly, if I select a 100 mm extrude, it will have perhaps 4 or 5 bursts and it will result in less than 100 mm being extruded.
Does anyone have an idea of what is going on and how to fix it?
Re: Extrude is choppy - broken into segments and not complete.
Try using Repetier Host and see if you get a different behavior.
