Printing House Numbers
Posted: Fri Mar 08, 2013 4:45 pm
by jesse
Does anyone know how to turn an image of a house numbers into a 3D model?
[img]http://images.lowes.com/product/convert ... 2014lg.jpg[/img]
Re: Printing House Numbers
Posted: Fri Mar 08, 2013 5:07 pm
by MorbidSlowBurn
Some cad programs have a text option that you can use to create 3d letters and numbers. I use SolidWorks myself for models.
Another option is to use Blender. There are tutorials on how to do 3d letters and numbers.
Both methods you export to an STL file that you put through your slicing program.
Posted: Fri Mar 08, 2013 5:43 pm
by jesse
My solution was to load the image into InkWorks and draw lines around it. Then delete the background and flood fill the region. Then delete the outline. Then export to an SVG graphic.
Then, take the SVG and load it into Blender. Then scale it up, use the extrude option, and add a bevel.
Then export to STL, and load it into Kisslicer to be turned into GCode.
[img]http://i.imgur.com/tG62OUX.png[/img]
Scaling in Blender
Tutorial on generating a STL from an image.
Posted: Thu Mar 21, 2013 9:00 am
by foshon
jesse wrote:My solution was to load the image into InkWorks and draw lines around it. Then delete the background and flood fill the region. Then delete the outline. Then export to an SVG graphic.
Scaling in Blender
Ingenious solution!! For what its worth there are a lot of OpenSCD options for letters and numbers on Thingiverse. Might save the not so technically versed among us some pain.
http://www.thingiverse.com/search?q=numbers&sa=
