V2 with Duet and smart effector
Posted: Mon Oct 14, 2019 2:13 am
by ClosetNerd
Ok so I decided that since I had finished grad school I needed to get the v2 that I had pieced together calibrated and running. I have upgraded the arms to the newer ball and socket 290 arms, Duet 2 board and the smart effector with v6 hot end. I have tried the setup several times and the auto calibrate but for some reason I cannot get this thing calibrated. I did try a test print but the x tower is substantially lower than the others. I am not sure how to solve this. Could somebody give me a better write up? Could I use V4 firmware as a starting point?
Re: V2 with Duet and smart effector
Posted: Mon Oct 14, 2019 8:17 am
Can you post your config.g file?
There is no "v4 firmware" - RepRapFirmware isn't like Repetier Firmware. With RRF, 100% of the configuration is done with G and M code commands and there's no need for any firmware changes. That being said, what version of the firmware is reported by the web interface?
tnx.
Posted: Mon Oct 14, 2019 11:00 am
by ClosetNerd
; Configuration file for Duet WiFi (firmware version 2.03)
; executed by the firmware on start-up
; generated by RepRapFirmware Configuration Tool v2.0.4 on Thu Sep 26 2019 21:24:04 GMT-0500 (Central Daylight Time)
; General preferences
G90 ; send absolute coordinates...
M83 ; ...but relative extruder moves
M550 P"My Printer" ; set printer name
M665 R140 L290 B140 H335 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet
; Drives
M569 P0 S1 ; physical drive 0 goes forwards
M569 P1 S1 ; physical drive 1 goes forwards
M569 P2 S1 ; physical drive 2 goes forwards
M569 P3 S1 ; physical drive 3 goes forwards
M584 X0 Y1 Z2 E3 ; set drive mapping
M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
; Axis Limits
M208 Z0 S1 ; set minimum Z
; Endstops
M574 X2 Y2 Z2 S1 ; set active high endstops
; Z-Probe
M558 P5 R0.4 H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
G31 P100 X1.30 Y-1.00 Z-0.79 ; set Z probe trigger value, offset and trigger height
M557 R140 S30 ; define mesh grid
; Heaters
M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
M143 H0 S120 ; set temperature limit for heater 0 to 120C
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C
; Fans
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
; Tools
M563 P0 D0 H1 F0 ; define tool 0
G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
; Custom settings are not defined
; Miscellaneous
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
Posted: Tue Oct 15, 2019 8:22 am
The steps/mm for the Extruder is completely bonkers if you've got the EZStruder on your machine. :)
Can you post the bed.g file as well? Sorry I forgot to ask for that earlier. :(
Posted: Wed Oct 16, 2019 6:59 pm
by ClosetNerd
Yes I have an older ezstruder. What should it be?
M203 Z25000
G28
M109 S0
M140 S0
M106 P0 S0
M106 P2 S0 H-1
G30 P0 X0 Y125 Z-99999
G30 P1 X108.24 Y62.5 Z-99999
G30 P2 X108.24 Y-62.5 Z-99999
G30 P3 X0 Y-125 Z-99999
G30 P4 X-108.24 Y-62.5 Z-99999
G30 P5 X-108.24 Y62.5 Z-99999
G30 P6 X0 Y62.5 Z-99999
G30 P7 X54.13 Y-31.25 Z-99999
G30 P8 X-54.13 Y-31.25 Z-99999
G30 P9 X0 Y0 Z-99999 S6
M106 P2 T50 S0.5 H1
G28
Posted: Thu Oct 17, 2019 8:41 am
Try this bed file: (replace the block of G30 calls in your file with the below set)
; bed.g file for RepRapFirmware, generated by Escher3D calculator
; 16 points, 6 factors, probing radius: 140, probe offset (0, 0)
G30 P0 X0.00 Y140.00 Z-99999 H0
G30 P1 X89.99 Y107.25 Z-99999 H0
G30 P2 X137.87 Y24.31 Z-99999 H0
G30 P3 X121.24 Y-70.00 Z-99999 H0
G30 P4 X47.88 Y-131.56 Z-99999 H0
G30 P5 X-47.88 Y-131.56 Z-99999 H0
G30 P6 X-121.24 Y-70.00 Z-99999 H0
G30 P7 X-137.87 Y24.31 Z-99999 H0
G30 P8 X-89.99 Y107.25 Z-99999 H0
G30 P9 X0.00 Y70.00 Z-99999 H0
G30 P10 X60.62 Y35.00 Z-99999 H0
G30 P11 X60.62 Y-35.00 Z-99999 H0
G30 P12 X0.00 Y-70.00 Z-99999 H0
G30 P13 X-60.62 Y-35.00 Z-99999 H0
G30 P14 X-60.62 Y35.00 Z-99999 H0
G30 P15 X0 Y0 Z-99999 S6
Did you create a bed map by chance? If you haven't, add "M375" to the end of your config.g file (this will load the bed map when the printer starts up) and then create a new macro called "Bed Map" with the following contents:
G28
M117 Bed Mapping RostockMAX
M558 P5 I0 A1 S0.05 R0.4 H20 F2500
M104 S0
M140 S0
M106 P0 S0
G29
M500
G4 S1
M106 P2 T50 S0.5 H1
G28
M117 NOTE Any Auto-Probe (G32) done after bed mapping will disable previous bed mapping!
Run the map and then try a print. Note that it's going to show you the results of the mapping operation, but it should compensate for any height differences when you print (that's the whole point behind the map).
Posted: Thu Oct 17, 2019 10:43 pm
by ClosetNerd
So do I included the M114 at the end of the bed file?
Also You mentioned the extruder speed is nuts? Could you suggest a starting value? And after I run the bed map, then I run M500 and print correct?
Posted: Fri Oct 18, 2019 7:49 am
There is no M114 at the end of the bed file. The file I pasted should be used as-is. You'll notice it also includes the M500 to save.
The extruder is going to be 182.0 if you're using .9 degree steppers.
Posted: Fri Oct 18, 2019 7:09 pm
by ClosetNerd
I am using 1.8 steppers from seemecnc site. So would I halve the value?
Posted: Sat Oct 19, 2019 8:12 am
It'll be around 94.6 I think. You can use the extruder calibration process in the v2 docs to nail down the exact value.
