static ip address
Posted: Sat Mar 21, 2020 6:50 pm
by felich
I have to go into another room to see what ip address Artemis received.
Is there any way to set a static ip address?
Re: static ip address
Posted: Sun Mar 22, 2020 12:51 pm
If you didn't change the name of the printer in config.g, you can access it via
http://artemis.local. If you renamed the printer, make sure there's no spaces in the name - you can access it via http://my_printer_name.local.
Posted: Fri Aug 14, 2020 8:46 am
by dc42
You can set a static IP address using M587 if using a Duet WiFi, or M552 if using Duet Ethernet. But many people use an address reservation on the router instead.
