Stepper Config for V2 Rambo to Duet Wifi 1.04
CaduTwo
Post by CaduTwo »
Hi. I'm converting a V2 to a Duet 2 Wifi 1.04. The Red/Green and Blue/Yellow stepper pairs were flipped on the prev. Rambo setup.
Rambo GR BY
Duet RG YB
Should I be rewiring the Duet connector to match the Rambo or is that something that the prev. owner fixed in firmware and I should change the Duet config file?
TYVM
Re: Stepper Config for V2 Rambo to Duet Wifi 1.04
It would probably be easier for you to just flip the direction in the configuration.
CaduTwo
Post by CaduTwo »
TY. The motors worked as it was previously wired. One axis required direction flipping in the config. Steve from smcnc mentioned that they would only need to be rewired if they stuttered instead of moving. On to the next step of figuring out why the SE300 Z probe is triggered at rest state and only deactivating when the Z-axis is moving up.
