bed stop heating after print start
Posted: Tue Oct 27, 2020 6:17 pm
by dany muise
Hi , i bought a rostock v2 used already assemble whit he280 hot end everything works, not fine tune yet but work.... problem is after i start the print, the bed stop heating up ,it work if i just heat up bed it will stay at desire temp as long as printer is on, it happen when i start printing, is anybody as that happen to them??HELP!!!!!
Re: bed stop heating after print start
Posted: Wed Oct 28, 2020 9:04 am
It sounds to me like your slicing software has inserted a command to turn the bed heat off. What are you slicing with?
Posted: Wed Oct 28, 2020 9:50 pm
by dany muise
cura 4.7
Posted: Thu Oct 29, 2020 9:12 am
I would look at the gcode output to see if there's a command that's turning the bed off.
Posted: Thu Oct 29, 2020 12:11 pm
by Mac The Knife
perhaps " M140 S0"
Posted: Thu Oct 29, 2020 9:27 pm
by dany muise
i cant find anything that say turn off bed or anything like it:((
Posted: Fri Oct 30, 2020 8:02 am
by Mac The Knife
It would be a "M" code, or a "G" code. Could you do a copy/paste of the first 10 or so lines of one of the problem files?
Re: bed stop heating after print start.... solved
Posted: Fri Oct 30, 2020 10:49 pm
by dany muise
hi ty for your time... problem solve ,my fault ,i reloaded firmware and put right value for power supply 2 instead of 1 end everything working find:))))\
just finish xyz test cube came out great:))) ty all
Posted: Sat Oct 31, 2020 8:38 am
\o/
