z height moves up when changing directions on xy plane
brand_in
Post by brand_in »
SOMEONE PLEASE HELP
When I do travel moves in a single direction the z is perfect, but as soon as I change to the opposite direction the nozzle lifts up about .2mm on a 10mm move
This phenomenon is more pronounced the further the nozzle is from the center
as you can guess when i do large prints the i get great adhesion going in one direction, and then when it switches direction it raises up and no squish
this is not z hop, it is when im just jogging the machine manually
Re: z height moves up when changing directions on xy plane
It sounds like your bed has a slight tilt to it.
brand_in
Post by brand_in »
negative, my bed is perfectly flat, when I change direction (xy) and tell the nozzle to go backwards 10mm to the spot it was just at, the nozzle is .2mm higher (z) than when it was at that same exact position the first time ( and as I continue going back to the center it gradually slopes back down to zero.
it essentially is a reputability issue, I tell the machine to go to the same spot but when coming from the opposite direction there is a z difference of .2mm to 0mm depending on how far away i am from the center
Then it's a mechanical issue of some kind. If the drive gears are plastic with a metal core, check to see if one has a crack. If they're all metal, make sure the grub screws aren't loose and allowing movement.
You also want to make sure that all three belts are in good shape and have an equal tension.
