I need the Default EEPROM settings
Posted: Mon Dec 13, 2021 12:38 pm
by Arremondo
I added a Wham Bam to my Rostock Max v2 with the HE280 upgrade. When I tried to auto-level it, the hot end would slam down on the Wham Bam and after approximately 3 tries would just keep pushing down causing me to have to cut the power. I went into the EEPROM settings and while fiddling with it, I managed to remove a setting and add another causing the printer to think the bed is way wider than it is. I would just like to reset everything to defaults but I don't know how. Please help!
Thank you!
Re: I need the Default EEPROM settings
Posted: Mon Dec 13, 2021 5:13 pm
by Arremondo
In case anyone is interested, I received the following from SEEMECNC about this and it worked for me:
You can factory reset by sending M502 first, then M500 to save. Power cycle after these commands.
You can make a gcode program in a text editor, name it somethin like reset.gcode and has 1 second pauses
M502
G4 S1
M500
G4 S1
Then turn off the printer, and turn on once the power supply is fully discharged.
Posted: Tue Dec 14, 2021 8:18 am
Glad to hear you got it sorted! I've got a WhamBam plate waiting to be installed on my BOSSDelta 300. Maybe I'll get to it over vacation. :D
