Max V4 Scaling problem
Posted: Sat Dec 18, 2021 6:18 pm
by brianmichalk
My horizontal scale is off by 1.5%. I just finished updating to the latest 3.2.2 firmware and recalibrated the machine, but the scale is still off.
I edited the arm length in config.g, but that doesn't help. The config-override.g still has the wrong lengths in there, but the comments say to not edit that file.
What's the accepted procedure for calibrating these days? Lots of older documentation out there.
For an RMax V4.
I have an Artemis, and old V3 that work just fine, so I know it's not my slicer. I am directly measuring the head position with calipers after moving from the dashboard, and these measurements are agreeing with my parts dimensions.
Re: Max V4 Scaling problem
Posted: Sun Dec 19, 2021 11:49 am
Please post your config.g file.
Posted: Sun Dec 19, 2021 1:42 pm
by brianmichalk
I just now noticed the last line. I'm looking into that now.
; SeeMeCNC 3D Printers
; General preferences
G90 ; absolute coordinates
M83 ; relative extruder moves
; Only remove ONE semi-colon for ONE printer configuration
M550 P"RostockMAXv4" ; set printer name (ARTEMIS, RostockMAX, BOSSdelta, SeeMeCNC, BestFriend, etc.)
;M665 R150 L339.47 B145 H380 ; Carbon Fiber ARMS (R delta radius, L diagonal rod length, B printable radius, H homed height default)
;M665 R150 L351.1 B145 H370 ; Injection Molded LONG ARMS 350mm length
;M665 R142.5 L291.5 B145 H400 X0 Y0 Z0 ; Standard Injection Molded Arms
M665 R142.5 L295.9 B145 H400 X0 Y0 Z0 ;bkm scaling. Standard Injection Molded Arms
M666 X0 Y0 Z0 ; endstop adjustment (this is set by autocalibration leveling)
; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet
; Drives
M569 P0 S1 ; physical drive 0
M569 P1 S1 ; physical drive 1
M569 P2 S1 ; physical drive 2
M569 P3 S1 ; physical drive 3
M569 P4 S1 ; physical drive 4
M584 X0 Y1 Z2 E3:4 ; set drive mapping
M350 X16 Y16 Z16 E16:16 I1 ; configure micro stepping with interpolation
M92 X200.00 Y200.00 Z200.00 E182.00:182.00 ; set steps per mm
M566 X700.00 Y700.00 Z700.00 E2000.00:2000.00 ; set maximum instantaneous speed changes (mm/min)
M203 X10000.00 Y10000.00 Z10000.00 E9000.00:9000.00 ; set maximum speeds (mm/min)
M201 X1200.00 Y1200.00 Z1200.00 E5000.00:5000.00 ; set accelerations (mm/s^2)
M906 X1500 Y1500 Z1500 E1400:1400 I40 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
; Axis Limits
M208 Z0 S1 ; set minimum Z
; End-stops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
; Z-Probe
M558 P5 I0 A4 R0.4 C"zprobe.in" H20 F2500 T6000 ; HOTEND PROBEset Z probe type to switch and the dive height + speeds
G31 P500 X0 Y0 Z-0.4 ; set Z probe trigger value, offset and trigger height
M557 R130 S30 ; define mesh grid
; Bed Heater
M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bed temp
M950 H0 C"bedheat" T0 ; create bed heater output on bed heat and map it to sensor 0
M307 H0 R0.245 C774.3 D25.92 S1.00 V12.9 ; Bed Heater Process Parameters
M140 H0 ; map heated bed to heater 0
M143 H0 S120 ; set temperature limit for heater 0 to 120C
; Hotend Heater
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
M307 H1 R2.800 C109.1 D5.12 S1.00 V13.0 ; Hotend Heater Process Parameters
M143 H1 S280 ; Hotend Max Temp
; Fans
M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency
M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"fan2" Q500 ; create fan 1 on pin fan1 and set its frequency
M106 P1 S0.80 H1 T45 ; set fan 1 value. Thermostatic control is turned on
; Tool Extruder 1
M563 P0 D0 H1 F0
G10 P0 X0 Y0 Z0
G10 P0 S0 R0
; Tool Extruder 2
M563 P1 D1 H1 F0
G10 P1 X0 Y0 Z0
G10 P1 S0 R0
;Filament Runout Sensor
M950 J0 C"!^e0Stop" ; create switch pin
M950 J1 C"!^e1stop" ; create switch pin
M581 P0:1 T2 S1 R1 ; run trigger2.g to pause if filament has run out during SD card printing
; Miscellaneous
M575 P1 S1 B57600 ; enable support for PanelDue
M501 ; load saved parameters from non-volatile memory
T0 ; select Tool 0
M911 S10.5 R11.2 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
M579 X1.0100 Y1.0100 Z1.0100 ; scale axis
Posted: Mon Dec 20, 2021 8:40 am
That file looks good. Can you also post your bed.g file? That will tell me what RRF is doing for the calibration.
tnx.
