Long beep power issue
Posted: Fri Jan 20, 2023 11:13 am
by Bigneil222
So when I’m using my Rostock Max V3, it’ll start a print go about two minutes then a long beep sound will happen freezing the entire printer. I can’t access the board and I cannot access the print menu. The only way around it is to turn it off wait, about two minutes and turn it on to restart the machine and I don’t know how to fix that issue. Can anybody please help me with this? Update as of 11:33am here if I even try to turn it on it has that solid long beep sound what should I do?
Re: Long beep power issue
Posted: Sat Jan 21, 2023 9:18 am
I would check the output of the power supply.
Posted: Sun Jan 22, 2023 11:01 pm
by Bigneil222
I will check that and get back to you
Posted: Sun Jan 22, 2023 11:09 pm
by Bigneil222
So I unplugged it removed the location from where it was moved it over to a different wall outlet, plugged it back in turned it on and then it started to beep immediately the reset button also does not work. Unless I’m hitting a different button that I should to reset it.
Posted: Mon Jan 23, 2023 8:31 am
That's not testing the output of the power supply. :)
Did you make any changes to the printer prior to the problem manifesting itself? (uploading firmware, etc.)
Posted: Mon Jan 23, 2023 9:27 am
by Bigneil222
no
