filement exdrution before printing
Posted: Sat Dec 09, 2023 8:03 am
by kuper
Hello,
I updated my duet, and after the printing finished, the filament retracted but when the printing started, it was not extruded to the hot end.
there were a few times that I used cura and the hot end went to the side of the bed and extruded a lot of filament at high speed to clean the nozzle and prepare for the printing.
how to do it? or with a g-code?
m115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.4 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2022-10-20 16:17:41
I used the seemecnc files to update.
thank you.
Re: filement exdrution before printing
Posted: Sun Dec 10, 2023 10:16 am
Look at the start & end gcode in Cura - if you're using a SeeMeCNC-built profile, it'll have the gcode in it for the retraction & priming of the filament.
