indicate platform to bed
Posted: Mon Mar 11, 2013 11:33 pm
Is there any reason I couldn't put a indicator in the platform and set a zero in the center of the bed and then use the same zero to set the three points in a circle for each tower. Then put the hotend back in heat everything up and then set my center z zero with feeler gage? If the platform is truly parallel to the bed then this should work correct? And the z should be the same at any point on the bed. Limits being the flatness of the build surface.
