Stringing
Posted: Tue Mar 12, 2013 6:09 am
Hello. I tryed alot with settings but i didnt get of this stringing on my prints. Anyone has an idea what i can change on my settings?
https://plus.google.com/photos/11410027 ... jfH0rs_tNg
My settings are:
ABS 1.75 filment
bottom_solid_layers = 2
bridge_flow_ratio = 1
bridge_speed = 30
brim_width = 0
complete_objects = 0
default_acceleration = 0
external_perimeter_speed = 80%
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extrusion_width = 0
fill_angle = 0
fill_density = 0.2
fill_pattern = rectilinear
first_layer_extrusion_width = 0
first_layer_height = 0.3
first_layer_speed = 30%
gap_fill_speed = 30
gcode_comments = 0
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_speed = 30
layer_height = 0.2
min_skirt_length = 0
notes =
only_retract_when_crossing_perimeters =
output_filename_format = composition.gcode
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 0
perimeter_speed = 30
perimeters = 2
post_process =
randomize_start = 1
skirt_distance = 0
skirt_height = 2
skirts = 6
small_perimeter_speed = 30
solid_fill_pattern = rectilinear
solid_infill_below_area = 10
solid_infill_every_layers = 0
solid_infill_speed = 30
support_material =
support_material_angle = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_pattern = rectilinear
support_material_spacing = 2.5
support_material_speed = 30
support_material_threshold = 0
threads = 4
top_solid_infill_speed = 30
top_solid_layers = 5
travel_speed = 300
bed_size = 280,280
end_gcode = M104 S0 ; turn off temperature\nM140 S0\nG28
extruder_offset = 0x0
gcode_flavor = reprap
layer_gcode =
nozzle_diameter = 0.3
print_center = 0,0
retract_before_travel = 5
retract_length = 0.1
retract_length_toolchange = 0
retract_lift = 0.5
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 55
start_gcode = G28\nG1 Z300 F7500
toolchange_gcode =
use_relative_e_distances = 0
vibration_limit = 0
z_offset = 0
bed_temperature = 55
bridge_fan_speed = 100
cooling = 1
disable_fan_first_layers = 1
extrusion_multiplier = 1,1,1
fan_always_on = 0
fan_below_layer_time = 60
filament_diameter = 1.75,75,1.75,75,1.75,75
first_layer_bed_temperature = 55
first_layer_temperature = 225,225,225
max_fan_speed = 100
min_fan_speed = 35
min_print_speed = 6
slowdown_below_layer_time = 20
temperature = 215,215,215
I tryed a retract length with 1mm but without any diffrent in stringing.
My settings are:
ABS 1.75 filment
bridge_speed = 30
brim_width = 0
extrusion_width = 0
fill_angle = 0
fill_density = 0.2
gap_fill_speed = 30
gcode_comments = 0
infill_extruder = 1
infill_speed = 30
layer_height = 0.2
notes =
perimeters = 2
post_process =
randomize_start = 1
skirt_distance = 0
skirt_height = 2
skirts = 6
support_material =
threads = 4
travel_speed = 300
bed_size = 280,280
layer_gcode =
print_center = 0,0
retract_lift = 0.5
retract_speed = 55
toolchange_gcode =
vibration_limit = 0
z_offset = 0
cooling = 1
fan_always_on = 0
max_fan_speed = 100
min_fan_speed = 35
min_print_speed = 6
