Time lapse video!
Time lapse video!
Check this out:
http://youtu.be/J1-TyeIX-KI
One frame every 30 seconds.
\o/
:D
cambo3d
Re: Time lapse video!
Post by cambo3d »
nice
rs50pilot
Post by rs50pilot »
I like how the lights are on then they go out then on again. Do you know how long it took?
Did you read the description text on the video? :D
MorbidSlowBurn
Post by MorbidSlowBurn »
Excellent.
Did the lower right space shift at the 0:37 mark? What is the dark surface you are printing on?
Yes, one of the spacers came un-stuck from the bed during the print. I can't get the bed any hotter than about 83C (the target temp was 90C and it never reached that point - I suspect my wire diameter is insufficient (using 2 pair of 18ga)).
The material is window tint on a borosilicate glass bed, which in turn is on mhackney's aluminum spreader plate.
MorbidSlowBurn
Hadn't heard the window tint idea yet. How does it hold up under printing? How often do you have to replace? Are you also using hairspray or another binder?
I have a similar temp issue. Planning on installing another pair of wires when I install mhackney's plate. Just need to find time.
It's my understanding that the tint material is PET tape, which has been recommended as a build surface. I've tried hair spray on the bare metal and it didn't turn out well. I've also tried hairspray on bare glass and that didn't work so well either. I strongly suspect the lower temperature to be a contributing factor to the print adhesion failures.
Hmm, I print on both aluminum and the borosilicate glass with hairspray at 70°C and it takes a sizable "POP" to get the parts off.
Try plating up a set of parts and try it. Single parts seem to be ok, but when you get away from the center the wheels come off. :)
