Rostock Max kit change log
Posted: Wed Mar 20, 2013 11:44 am
by dbarrans
I thought I'd start a thread here to document changes to the kits as shipped from SeeMeCNC. It'd be great if they would update this as well. Here are some changes I've seen from newer posts since I got my kit, in no particular order.
* The hot end now has a relief hole into the side of the resistor hole.
* New mounting holes have been added for the RAMBo on the interior partitions of the base.
* Onyx is now included with the kit.
* The design of the nozzle has changed.
* The RAMBo has been updated. I know about the 8-16 change, but what else changed?
* An LCD adapter is now included with the LCD option.
- dan
Re: Rostock Max kit change log
Posted: Wed Mar 20, 2013 11:51 am
by dbarrans
Injection molded spacers for the belt idler bearings.
- dan
Posted: Wed Mar 20, 2013 12:51 pm
RAMBo was updated to version 1.1 and the list of differences are here on the manufacturer's site:
https://ultimachine.com/rambo and here:
http://reprap.org/wiki/Rambo
Posted: Tue Apr 09, 2013 10:26 am
by dbarrans
20-tooth plastic GT2 pulleys have replaced 15-tooth aluminum pulleys.
John told me "Yes, we are now shipping with 20 tooth pulleys. The firmware changes needed are to adjust your steps per mm in configuration.h from 106.666 to 80.000 for X Y and Z axes, and that's all."
- dan
Posted: Wed Apr 10, 2013 9:35 am
This is also mentioned in the latest doc update I pushed.
Posted: Sat Apr 20, 2013 8:42 pm
by dbarrans
I saw John said they're machining the arms now, so they don't need to be sanded.
- dan
Posted: Tue Apr 23, 2013 7:51 pm
by johnoly99
LCD Controller is included with all kits now
Acrylic is no longer an option, white and black melamine only
The door for the right side has no holes anymore cut in it
608 Bearing covers are now black acetal instead of white (they're purdy'er)
Repetier Firmware now flashed on all kits shipping after 4/23/2013 ( link is
https://github.com/seemecnc/RepetierMAX )
